hi nv team,
The customer want to flash jp5.0.2 on xavier nx through l4t_initrd_flash.sh of packaged system tar file.
But here is compatible issue because the device cann’t reboot.
the error log is “Waiting for target to boot-up” and timeout. at the same time, host machine cann’t find 0955:7035 by lsusb.
basic information are:
1、device is rcm mode and host flash
when device is rcm mode, the host machine flash cmd is:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --massflash 1
2、the physical machine is assembly machine, included of asus motherboard, intel cpu, x86_64 arch;the host os is ubuntu 20.04;
the same applies to dell G16 7630 and IMB-1110 of industrial motherboard.
But these physical machine can flash jp4.6.2 for xavier nx.
3、relatively, thinkapd T14/Ubuntu 20.04 can flash successfully.
preliminary analysis are:
1、usb typec cable is ok by cross validation;
2、host usb port is the same one, or usb2.0 hub;
3、the device cann’t reboot during flashing and the host is waiting for boot-up until timeout.
But I don’t know host machine’s constraint condition and the root cause.
this flash cmd don’t work, and the prompt message is “xxx/flash.sh is not found”.
the massflash package is generated by “Workflow 3: To massflash the backup image” of “Linux_for_Tegra\tools\backup_restore\README_backup_restore.txt”.
Because the customer and odm factory don’t have sdkmanager environment and the relevant opetations are complicated. They only have one ubuntu host machine.
[0357.614] E> I2C: slave not found in slaves.
[0357.615] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start t.
[0357.621] E> I2C_DEV: Failed to send register address 0x00000000.
[0357.627] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 a.
[0357.636] E> eeprom: Failed to read I2C slave device
[0357.641] I> Failed to read CVM eeprom data
[0357.645] E> Error getting EEPROM data!
It’s either hardware failure, or please check Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg and Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg to see if you accidentally modified reading size of the EEPROM on the module:
