Host was blocked after calling a nested kernel?(꒦_꒦)
I wrote CUDA code like below: once the total parent threads exceeds a number, program is blocked in hundreds of frames(seems the more sub-threads configed the more stably the program is o(╥﹏╥)o), and the threads counter is not correct and unstable when error happens. so what’s the rule of configing a nestted CUDA kernel?
__global__ void  sub_kernel(int* counter)
    int index = atomicAdd(counter, 1);
__global__ void  kernel(int * counter)
    sub_kernel << <800, 80 >> > (counter);  // this version has much more threads but work well (very slow) !!
    // sub_kernel << <10, 10 >> > (counter);  // will cuase host die in hundreds of frames
int TT()
    int* fragCounter_dev = nullptr, counter = 0;
    CHECK(cudaMalloc(&fragCounter_dev, sizeof(int)), End);
    kernel << <32,  128>> > (fragCounter_dev);
    // kernel << <32, 32 >> > (fragCounter_dev); // ok for any sub-kernel config
    CHECK(cudaGetLastError(), End);
    CHECK(cudaDeviceSynchronize(), End);  // blocked here in case of error
    CHECK(cudaMemcpy(&counter, fragCounter_dev, 4, cudaMemcpyDeviceToHost), End);
    CHECK(cudaFree(fragCounter_dev), End);
End:
    return counter;
int main(int argc, const char** argv)
int key = 0;
int frame = 0;
while (key != 0x20)
    int threads = Cuda::TT();
    cout << ++frame << "--" << threads << endl;
    cv::waitKey(10);
return 0;
Device properties:
totalGlobalMem 8589606912
sharedMemPerBlock 49152
regsPerBlock 65536
warpSize 32
memPitch 2147483647
maxThreadsPerBlock 1024
  • maxThreadsDim 0x000000524cd8f674 {1024, 1024, 64}
  • maxGridSize 0x000000524cd8f680 {2147483647, 65535, 65535}
    clockRate 1695000
    totalConstMem 65536
    major 7
    minor 5
    textureAlignment 512
    texturePitchAlignment 32
    deviceOverlap 1
    multiProcessorCount 34
    kernelExecTimeoutEnabled 1
    egrated 0
    canMapHostMemory 1
    computeMode 0
    maxTexture1D 131072
    maxTexture1DMipmap 32768
    maxTexture1DLinear 268435456
There are various nesting limits and resource constrains when calling nested kernels. These are covered in the CDP section of the CUDA programming guide. Exceeding such limits will eventually cause kernel failures, which can certainly cause “host to die”. Stated simply, large numbers (say tens of thousands, or more) of outstanding kernel launches, or large nesting depths (hundreds) are simply not possible. The GPU doesn’t have enough resources to keep track of a nearly infinite amount of outstanding work and such designs should be avoided.
You can do error checking on CDP/Nested kernel launches just like you can in host code, and this would be one of my recommendations, to help see what is going on.
