Is the hot-reloading extension functionality supported in Docker? I can’t get a dockerized version of Isaac Sim 4.5 to automatically detect file changes. When using the same extension on Isaac Sim 4.5 running on bare metal Ubuntu 22.04, hot reloading works without issues.
Additional Information
What I’ve Tried
I ran inotifywait inside the docker container, and all file change modifications in the extension folder are being correctly reported.
I confirmed that the extension.toml has the setting reloadable = true.
Yes. Naturally I cannot easily use VSCode to edit files inside the container. But I followed the linked example and used touch ./exts/isaacsim.examples.interactive/isaacsim/examples/interactive/hello_world/hello_world.py to trigger a file modification event.
When running bare-metal, this triggers reload of the example (and the relevant extension UI disappears). In docker, nothing happens.
Hi @VickNV@robot_human_dev , I have the same issue here. Saving the files in the container does not reload the extension. I use an AWS cloud installation of IsaacSim 4.5.0. I am using vscode Dev Containers extension to connect to the container running isaac sim, so I am able to edit and save the files of the extension in the container, but saves do not reload extensions.
For now I resort to reload manually the extensions, with either of these two methods :
Deactivate and reactivate the extension from the extensions window in isaac sim (Window > Extensions, find the extension, click the toggle to deactivate, click to reactivate).
Alternatively, use a script with the script editor to toggle extension reload. For instance, to toggle the hello world interactive example extension, load the following script in the script editor:
Note: Unfortunately on my side it was not possible to unable and enable an extension in a single run of the script editor, so the solution is to use a toggle script, and running it twice.
Hi @VickNV is there any update on this? I have the exact same problem, we have multiple people sharing a dev container and we are resorting to using a toggle like @t.reid suggested, but sometimes we will just have to restart the whole app.
The hot reloading is an awesome feature that I have grown used to and its really painful when it is ripped away as soon as docker containers are involved.
Under the assumption that Isaac Sim utilizes inotify to detect extension file changes (which seems reasonable), I did some research. It seems inotify doesn’t work inside a Docker container. By default, Docker uses overlayfs what appears to have issues with inotify.
A potential fix might be to make Docker use fuse-overlayfs instead which could support inotify in theory. But from what I’ve read online it might not just work out-of-the-box together.
I wasn’t able to fully test it because the transition to fuse caused some XRDP issues with my container and I had to revert back to overlayfs before I could start Isaac Sim under fuse. But your container setup might be different.
The root cause is that filesystem change notifications (inotify) don’t propagate correctly through Docker’s volume mounts, so the Kit extension system doesn’t detect file changes for hot reload.
Current workaround: Disable and re-enable the extension via the Extension Manager (or programmatically) after editing code, rather than relying on automatic hot reload.
Closing this forum topic in favor of the GitHub issue where the fix can be tracked. Please subscribe to #288 for updates.
