Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Topic Description
This issue has already been described here for an older version of IsaacSim.
However, IssacSim 4.5 BaseSampleUITemplate
doesn’t take a parameter keep_window_open
, so the solution provided back then is not applicable.
Q: How can I prevent my extension closing every time the code is reloaded?
Details
I assume the the problem lies in the following method provided by the extension UI template VS code generates automatically:
def cleanup(self):
"""Clean up window and menu"""
if self._window is not None:
self._window.destroy()
self._window = None
# destroy menu
if self._menu is not None:
try:
omni.kit.ui.get_editor_menu().remove_item(self._menu)
except:
omni.kit.ui.get_editor_menu().remove_item(self._menu_path)
self._menu = None
However, if I remove / change this cleanup method, the window stays open, but hot reloading doesn’t work anymore.
