I am able to create a hotspot network using nm-connection-editor interface but hotspot network is not visible on any of the other devices.
Hi ug201311001, have you tried this procedure from the wiki?
https://elinux.org/Jetson/TX1_WiFi_Access_Point
As described in the wiki entry, the wireless driver’s op_mode parameter needs set to ‘2’ to enable SSID broadcast.
This worked for me. Thanks
