What are the steps used for the time range or is it some type of random distribution that is used? Is it possible to change this to use time steps or other options?
Yes sampled uniformly in that range. For future reference in the parameterization class you’ll fine the sample function which calls the _sample_ranges function for each variable which is indeed uniformly sampling. Unless of course you choose quasirandom sampling or provide a discrete list / fixed value/ etc.
For fixed time-steps you could replace that tuple with a numpy array and it will select a value from the given array. Have a look at this source code here to see what happens for a given input. Hope this helps!
