Hi everyone,
Logistics: I’m using CUDA 2.2, CUDA Programming Guide 2.2.1, GPU = Quadro NVS 295 (Compute Capability 1.1)
This is a related question to the topic I posted a few hours ago that avidday helped me solve. This time, my question revolves around how texture values are loaded into a texture cache? My code (which is attached), is a simple program that just loads an array of values. The array is really a 2D array, indexed by row major order. Each “row” in the host array is set to the row number + 1.
In the code, when I’m in the device, right now I’m simply trying to read the values out that are written to the texture cache. When I run my program, I get the following (for a 3x3 test):
Initial Array
1.000000 1.000000 1.000000
2.000000 2.000000 2.000000
3.000000 3.000000 3.000000
Texture Array
1.500000 1.500000 1.500000
2.500000 2.500000 2.500000
which seems a bit odd to me since I would expect the Texture Array to have the same values as the Initial (Host) Array. I’ve tried searching the forum for an issue like this, and searching online, but I haven’t found anything like this. Does anyone know why this might be happening? My guess is that it probably has something to do with the cudaMemcpyToArray() function, but I can’t find anything wrong with my call.
Thanks for your help,
Matt
