**• Hardware Platform: jetson orin nx
**• DeepStream Version: 7.0
**• JetPack Version: 6.0GA
**• TensorRT Version: TRT 8.6.2.3
Hi!
When I run the following code,an error occurs.I want to know why this happened and how to deal with it.
ERROR: gst-stream-error-quark: Internal data stream error. (1): …/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstAppSrc:realsense-source
The code is:
def on_need_data(source, user_data):
frames = pipeline_rs.wait_for_frames()
color_frame = frames.get_color_frame()
color_image = np.asanyarray(color_frame.get_data())
if color_frame:
buf = Gst.Buffer.new_wrapped_bytes(GLib.Bytes.new(color_image.tobytes()))
flag = source.emit("push-buffer", buf)
if flag != Gst.FlowReturn.OK:
print("error")
return flag
def main():
platform_info = PlatformInfo()
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
# Source element for reading from intel realsense
print("Creating Source \n ")
source = Gst.ElementFactory.make("appsrc", "realsense_source")
if not source:
sys.stderr.write(" Unable to create Source \n")
# Use videoconvertor to convert from BGR8 to RGBA as required by nvinfer
print("Creating Video Converter \n")
vidconv = Gst.ElementFactory.make("videoconvert", "convertor_src")
if not vidconv:
sys.stderr.write(" Unable to create videoconvert \n")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Use nvinfer to run inferencing on decoder's output,
# behaviour of inferencing is set through config file
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
# Use convertor to convert from NV12 to RGBA as required by nvosd
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvidconv \n")
# Create OSD to draw on the converted RGBA buffer
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
# Finally render the osd output
if platform_info.is_integrated_gpu():
print("Creating nv3dsink \n")
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
if not sink:
sys.stderr.write(" Unable to create nv3dsink \n")
else:
if platform_info.is_platform_aarch64():
else:
print("Creating EGLSink \n")
sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
# set appsrc element
caps_string = "video/x-raw, format=BGR, width=1280, height=720, framerate=30/1"
source.set_property("is-live", True)
source.set_property("format", Gst.Format.TIME)
source.set_property("caps", Gst.caps_from_string(caps_string))
source.connect("need-data", on_need_data)
# set nvstreammux element
if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
streammux.set_property('batch-size', 1)
pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
print("Adding elements to Pipeline \n")
pipeline.add(source)
pipeline.add(vidconv)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
# link the elements together
print("Linking elements in the Pipeline \n")
source.link(vidconv)
sinkpad = streammux.request_pad_simple("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
vidconv.link(streammux)
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
# start play back and listen to events
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
