How can custom data be sent and received when using the Python backend in Triton?
NVIDIA RTX A4500
• DeepStream Version
7.1
• TensorRT Version
default tensorrt in nvcr.io/nvidia/deepstream:7.1-triton-multiarch
Driver Version: 535.161.08
CUDA Version: 12.2
questions
hello,
I am using the Python backend in Triton Server, and after processing, I return custom JSON data. Now, I need to retrieve the JSON data in the Probe. Is this approach feasible, or do I need to modify the nvinferserver source code to accept custom results? or can I modify the source code of custom_lib to accept custom data?
python backend code:
data = {
“video_has_board”: “ok”,
“video_distance”: self.video_distance,
“video_angle_ok”: self.video_angle_ok,
“focal_length”: self.focal_length,
“normal_vector”: self.normal_vector.tolist(),
“D”: self.D.tolist()
result = json.dumps(data, ensure_ascii=False, separators=(‘,’,‘:’))
out = np.array(result)
out_tensor = pb_utils.Tensor(‘results’, out.astype(output_dtype))
inference_response = pb_utils.InferenceResponse(output_tensors=[out_tensor])
responses.append(inference_response)
return responses
How can the custom responses mentioned above be retrieved through the nvinferserver component or other methods?
In terms of python backend, please refer to this faq.
OK,Thanks
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
