How can get the id of frame in pipeline of Deepstream?
Are there a solution how to get the ID of each frame in the pipeline after decoding video file. !!
i need the ID of frames to synchronize my custom metadata ( matrix homography ) with frames.
thank you.
• DeepStream Version
• TensorRT Version
Hello Sir,
i had this informations in my system:
• Hardware Platform (Jetson / GPU) ===> Jetson Xavier AGX
• DeepStream Version===> version is 5.0
• JetPack Version (valid for Jetson only) ===> Jetpack 4.4
• TensorRT Version===> version 7.1.3.0
• NVIDIA GPU Driver Version (valid for GPU only)===> 3.1.1 (not sur)
I want to add in the plugin Ds-example (who found it here: /opt/nvidia/deepstream/deepstream-5.0/sources/gst-plugins/) the option of video_stabilize ( code found here: /usr/share/visionworks/sources/demos/videos_stabilizer) , but i need the Id of each frames .
Help me Please
What is the mean of video ID? do you mean video frame number? Suppose video decoder is open source plugin. You can do anything in it.
Hi #Kesong,
  • i want to mean is the frame number or the frame ID it is the same ( but not the video ID).
  • This is what i do in pipeline :
    source=video.mp4 —> Nvdecoding ---->Dsexample(+: homography)—> NvInfer—>Nvtrack(KLT) (++: calibration bbox by homography)---->Nvsink
    but i need from the step (++) of pipeline the ID of frame to synchronize my metadata homography with the Frames.
i’m looking in decoding source if it is open source ,
Thank you
What is the status here? Is there still any issue?
