After I set the customed .target file as a default, I booted this Jetson orin NX 16GB(in more detail, it’s the IPC from Advantech, MIC-713 OX4A1 model). But the .target file has deleted and I didn’t know I deleted it. Eventually, the machine can’t be booted after UEFI screen.
I’m not sure I can check the Jetpack version even though I haven’t used the SDKmanager to flash the kernel. I flashed the RT-patched kernel with the command “sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 p3509-a02+p3767-0000 internal”
I tried the ‘sudo apt-cache show nvidia-jetpack’, it doesn’t show the version but
“N: Unable to locate package nvidia-jetpack
E: No packages found”
Is there any way to get the consol log even if the machine can’t be booted?
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
You can just keep capturing the serial console if your board can not boot successfully.
There should be still message output until it gets failed. We want to check those messages
