**• Hardware ** • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
The vehiche type model and vehichemake model can be added to the lpr pipeline as third and fourth SGIE. There are already lots of samples of how to add SGIEs in python. Please read the source code of deepstream test2 carefully.
