I read ‘Jetson AGX Xavier Series Camera Module Hardware Design Guide’ on the download center, but there are only a hardware design description about jetson board itself. Not the how to connect jetson with the camera. I think I`m missing something. Can you recommend more specific documents?
You need design a camera interposer module to connect the camera to Jetson AGX camera connector. The camera design guide include the pin definition of the B2B connector on Carrier board.
Here is the recommended mating terminal connector to be used.
Hi @yjsun111 I am facing the same problem, how you connected raspberry-pi cameras on the AGX Xavier Camera Connector? I am looking for a low cost solution.
For instance the cheapest solution (without using a USB camera) is to pay $179 on this kit:
since Jetson Xavier XN using the same chip version as Jetson AGX Xavier. you may consider to work with Xavier NX, and that’s by default support Raspberry PI v2, IMX219.
BTW, please do submit another new discussion thread instead of replying these old threads.
