Multiple rtsp sources will compute with multiple algrithm models. The relation between them is multi-vs-multi. Is there any reference examples or solution?
Appreciate for your replies!
You can refer to
This way is not sufficient to multi-vs-multi relation. I have find a solution. Every rtsp constructs a pipeline . And every model constructs a pipeliine. Then rtsp pipelines and model pipelines are linked by “appsink” elements pushing buffer to “appsrc” elements.
