Hi Guys,
I have just strated with CUDA and C in general so forgive my ignorance. I have decided to run the sample projects from visual studio IDE as the command lines seem so complex[any comment?]. A general question, how can i deploy my project physically into the GPU? is it by setting active solution configuration into Release and not debug, emudbg and emyrelease?
is there any documentation on the good practises to test then deploy the projects into the GPU
Thanking you in anticipation
