Yes. But I don’t want to the terminal display when the machine starts and disable CONFIG_FRAMEBUFFER_CONSOLE is OK. But it will be error when I run the app.
Can I solve this promble?
I don’t think fb console is related to the issue. What is the exact error message here?
Maybe you doubt my app. So I show you the mmapi sample 08.
sudo ./video_dec_drm --disable-video
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
Set governor to performance before enabling profiler
Using VT number 3
VT_WAITACTIVE failed, err=Input/output error
The screen just display a black background.
sample08 use drm. And it works well when I “sudo systemctl set-default multi-user.target”, if I enable CONFIG_FRAMEBUFFER_CONSOLE.
Do you remember to ublank the fb before running the app? Could you share me the command you are using to unblank?
I use the mmapi nvdrmrender.cpp. Maybe
drmModeSetCrtc(drm_fd, drm_crtc_id, -1, w_x, w_y, &drm_conn_id, 1, NULL);
Please follow the document here to unblank the monitor.
https://docs.nvidia.com/jetson/l4t-multimedia/l4t_mm_08_video_decode_drm.html
Before all the operations, I do this first.
sudo systemctl set-default graphical.target
The same result.
If I disable CONFIG_FRAMEBUFFER_CONSOLE, not work.
If I enable CONFIG_FRAMEBUFFER_CONSOLE, works well.
