Essentially as the title says. I have a camera driver and I want to be able to use the read_reg and write_reg functions in my user space application. I’m assuming it should be done through IOCTL and I have seen examples using file_operations but my driver doesn’t use that.
hello richardcusolito1,
may I know what’s the real use-case?
besides, there’s OEM firewall to block nvcsi register read/writes.
I want to be able to read and write to specific addresses using i2c to help with debugging my driver. There are also other ops I want to be able to call in userspace besides just the read/write so I figured if I could expose those I could expose any that I want.
please refer to below function for reading the register values via kernel driver side.
you may implement a debugfs, or, customize IOCTL to access to sensor driver by yourself.
static inline int ov5693_read_reg(struct camera_common_data *s_data,
u16 addr, u8 *val)
int err = 0;
u32 reg_val = 0;
err = regmap_read(s_data->regmap, addr, ®_val);
*val = reg_val & 0xFF;
This is exactly the function I want to expose to userspace. This is where my original question comes in. I don’t know the steps I need to take (what files I need to edit) to allow this to happen. Could you provide some insight on this?
you may see-also reference driver, nv_ov5693.c
for the demonstration to create debugfs,
for instance, ov5693_debugfs_create()
