How can I get Caffe or NVCaffe installed on my DPX2
I’m trying to install nvcaffe with the below link, but errors occurred when I execute make all -j4
https://www.nvidia.cn/object/caffe-installation-cn.html
Here is the errors prompts:
CXX examples/siamese/convert_mnist_siamese_data.cpp
CXX .build_release/src/caffe/proto/caffe.pb.cc
LD -o .build_release/lib/libcaffe-nv.so.0.17.0
AR -o .build_release/lib/libcaffe-nv.a
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/libturbojpeg.a(libturbojpeg_la-turbojpeg.o): relocation R_AARCH64_ADR_PREL_PG_HI21 against external symbol `__stack_chk_guard@@GLIBC_2.17' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: /usr/lib/gcc/aarch64-linux-gnu/5/../../../aarch64-linux-gnu/libturbojpeg.a(libturbojpeg_la-turbojpeg.o)(.text+0x64): unresolvable R_AARCH64_ADR_PREL_PG_HI21 relocation against symbol `__stack_chk_guard@@GLIBC_2.17'
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
Makefile:600: recipe for target '.build_release/lib/libcaffe-nv.so.0.17.0' failed
make: *** [.build_release/lib/libcaffe-nv.so.0.17.0] Error 1
Is there a guideline to install caffe or NVcaffe on px2? thank you.
Dear zew_wang,
Can I know why you want to install Caffe or NVcaffe on DPX2?
Because DPX2 is a platform suitable for deployment rather than training. Therefore, it is a good system to use the trained model to refer to using TensorRT. Thanks.
Dear Steve
I want to train the model with caffe, since training on the DPX2 will take fewer time than on my pc.
Does PX2 support any deep learning framework that I can training on? Thanks.
Dear zew_wang,
The link below may help. Thanks.
Hi Steve, I have got caffe installed on dpx2 and I’m training a model base on VOC dataset.
The training process is quite slow, even slower than my pc(GTX 1070)
When I set the batchsize to 8, it will out of memory.
I’m curious about that, Why?
Dear zew_wang,
I think this is expected behavior. Please check GTX1070 spec and dGPU spec on DPX2.
GTX 1070 : https://www.nvidia.com/en-us/geforce/products/10series/geforce-gtx-1070-ti/
dGPU in DPX2 : ./deviceQuery in /NVIDIA_CUDA-9.0_Samples/1_Utilities/deviceQuery$ on DPX2. Thanks.
