As the title i mentioned,i send a gPRC request to my Triton Server successfully,but i got a super weried response,it`s not what i expect string with label,instead is a weried encoded Python string like this:
[[b'680.980530:226010' b'657.416748:224994' b'654.782410:225830'
b'652.399475:225174']]
To figure out why it return like that,here is my Python client side code below:
outputs = [
grpcclient.InferRequestedOutput('output0',class_count=4),
inputs = [grpcclient.InferInput('images', img.shape, 'FP32')]
inputs[0].set_data_from_numpy(img)
result = triton_client.infer(
'action_trt',
inputs,
request_id=str('1'), # randomly input
model_version='',
outputs=outputs)
#got server response
output_array = result.as_numpy('output0')[0] # change it into numpy array
print(output_array)
And here is my config.pbtxt like this:
platform: "tensorrt_plan"
max_batch_size: 1
input [
data_type: TYPE_FP32,
dims: [ 3,640,640 ],
output[
dims: [ 25200,9 ]
label_filename: "labels.txt"
version_policy: { latest { num_versions: 1 } }
instance_group: [
count: 1
kind: KIND_GPU
gpus: [ 0 ]
So how can i fix that,since i have a school projecct close to ddl,it`s really need “Cardiotonic” for me and let me make a hot rush.
Huge thanks and regards
Elin Liu
