• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version Deepstream 7.1
• JetPack Version (valid for Jetson only) Jetpack 6.1
• TensorRT Version 10.3.0.30
• Issue Type( questions, new requirements, bugs) questions
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) How can i get video/rtsp source FPS info in nvmsgconv
I want to modify the /opt/nvidia/deepstream/deepstream-7.1/sources/libs/nvmsgconv/deepstream_schema/eventmsg_payload.cpp
file,
so i can get source fps in return meta, using kafka as consumer,using generate_dsmeta_message_minimal
fuction!
