I have an image sensor with data lane swapped [D0 ↔ D1].
Because I want to acquire images with this sensor, csi5_fops.c
Set brick_config.lane_swizzle.
/* Brick config */
memset(&brick_config, 0, sizeof(brick_config));
brick_config.phy_mode = (!is_cphy) ?
NVCSI_PHY_TYPE_DPHY : NVCSI_PHY_TYPE_CPHY;
+ brick_config.lane_swizzle = NVCSI_LANE_SWIZZLE_A1A0B0B1;
And using the kernel image I built, I was able to get a RAW image via V4L2.
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
However, when I using nvarguscamerasrc
, I got the same error as before changing lane_swizzle
and couldn’t get the image.
GStreamer Error:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Camera Trace:
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/3:0-2740 [003] .... 1234.231862: rtcpu_vinotify_event: tstamp:40085677986 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:1282741483424 data:0x719cc80010000000
kworker/3:0-2740 [003] .... 1234.231875: rtcpu_vinotify_event: tstamp:40085678164 cch:1 vi:0 tag:VIFALC_TDSTATE channel:0x0b frame:0 vi_tstamp:1282741526080 data:0x0000000031000001
kworker/3:0-2740 [003] .... 1234.287754: rtcpu_nvcsi_intr: tstamp:40086607642 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/3:0-2740 [003] .... 1234.287764: rtcpu_nvcsi_intr: tstamp:40086607642 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/3:0-2740 [003] .... 1234.287767: rtcpu_nvcsi_intr: tstamp:40086608344 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/3:0-2740 [003] .... 1234.287769: rtcpu_nvcsi_intr: tstamp:40086608344 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
I also tried the reverse pattern for verification.
If you use a kernel image with a normal sensor and a modified lane_swizzle
, V4L2 fails and you can get the image in Argus.
How can I give Argus “lane_swizzle” effect?
I using
- Orin NX module
- L4T R35.3.1
