How can I import a plain PNG image on Isaac Sim?
I am trying to do some 2.5 simulation where my robot would pick from a pile of pre-collected images. I would like to plain display those images on a plane prim.
I have followed a question on how to set a texture for prim but it just does not work. Adding 2D image as texture to a height-field
I ran the script but I just see a brownish plane that has nothing to do with the image.
Any hint?
The final effect should be something like this (Taken from a Blender tutorial).
@simone.zandara are you looking to do it programmatically or via GUI? if the former, you can follow the snippet from the doc and see if it works for you:
https://docs.omniverse.nvidia.com/isaacsim/latest/how_to_guides/environment_setup.html#creating-modifying-assigning-materials
if you’d like to know how to do it via GUI, i can make a short clip if that’d help.
For now I solved it with Blender but my idea is to do programmatically and swap the texture image at simulation time to perform different picks.
Thanks for the link. I will give it a shot.
I just came across this thread. I’m in the process of setting up scenes for creating a synthetic dataset, and it would be greatly helpful if I could directly import plain image files like PNG or JPG. Could you share the short clip for the GUI that was mentioned earlier? Thanks
