How can I integrate “nvdsanalytics” to my deepstream code, I am mainly using the following configuration file “deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt” to perform object detections?
please refer to \opt\nvidia\deepstream\deepstream-6.2\sources\apps\sample_apps\deepstream-nvdsanalytics-test\README, especially the section “The nvdsanalytics plugin can also be used along with reference deepstream-app” .
Thank you very much for your answer, mainly I run deepstream with the following command: “deepsream -c deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt”. To run nvdsanalytics can I do the same thing? My intention is to be able to run dashcamnet with nvdsanalytics. How can I integrate these two technologies?
