I am implementing a model that need to process one more level of processing before pushing the results to end service.
I can think of two approaches
- Doing the secondary processing inside the jetson device and giving final output to next stage- Needs deepstream integration with another python program inside the same device.
- Performing Secondary Processing in another system-Needs an interface mechanism to connect with another system.
I would like to know, pros and cons of each approach and whis is the better approach for realtime processing.
• Hardware Platform (Jetson)
• DeepStream Version 5.0.1
• JetPack Version (4.4)
