Hey,
Im developing a deepstream pipeline using cpp language.
Inside the prob function, I need to check if the frame has 3 channels (RGB) or 1 (IR).
how can I check the number of channels in the meta property or in some other variable?
I know that in python there is a ‘shape’ function that gives you that value.
You can get the color format in your probe function:
GstStructure *structure;
const gchar* format;
format = gst_structure_get_string (structure, "format");
