How can I make a mesh invisible in rendering while keeping it detectable by RTX LiDAR in Isaac Sim 6.0?
I’m using Isaac Sim 6.0.0 and I’m trying to combine a photorealistic 3DGS scene with RTX LiDAR.
Goal
I would like to use:
  • a 3DGS model for photorealistic rendering
  • a separate mesh for RTX LiDAR detection and collision
The final result I want is:
  • The 3DGS model is visible in the viewport and camera.
  • The mesh is invisible (or fully transparent) in rendering.
  • RTX LiDAR still detects the mesh.
Current workflow
  1. Capture a real object using 3D Gaussian Splatting (3DGS).
  2. Convert the generated .ply to .usdz using 3DGRUT.
  3. Import the USDZ into Isaac Sim.
  4. Since the 3DGS model is not detected by RTX LiDAR, create a simplified mesh (.fbx) of the same object.
  5. Import the FBX and align it with the USDZ model.
Current result
The workflow is partially successful.
  • The USDZ looks photorealistic but is not detected by RTX LiDAR (this is expected).
  • The FBX is correctly detected by RTX LiDAR, and I can see the point cloud in RViz as expected.
However, the FBX is also rendered as a visible white mesh, which hides the photorealistic 3DGS model behind it.
The problem is not LiDAR detection.
The problem is that the visible FBX mesh blocks the appearance of the 3DGS model.
What I have tried
I tried disabling the FBX using the eye icon (Stage Visibility).
This hides the FBX visually, but RTX LiDAR also stops detecting it.
Therefore, Stage Visibility cannot be used for this purpose.
My question
Is there a recommended way to achieve the following?
  • Render only the 3DGS USDZ.
  • Keep the FBX hidden from rendering.
  • Still allow RTX LiDAR to detect the FBX geometry.
Is there a material, render setting, RTX sensor option, or another workflow that supports this?
Environment
  • Isaac Sim 6.0.0
  • RTX LiDAR
  • 3DGS .ply converted to .usdz using 3DGRTU
  • Separate .fbx mesh used for LiDAR and collision
  • ROS 2 + RViz2
I’ve attached screenshots showing:
  1. The Isaac Sim viewport, where the visible FBX hides the photorealistic 3DGS model.
  2. The RViz2 point cloud, showing that the FBX is successfully detected by RTX LiDAR.
Any suggestions or recommended workflows would be greatly appreciated.
Thank you!
Good write-up - the problem is clear and your diagnosis is correct. The core issue is that Isaac Sim’s stage visibility toggle (invisibleInStage) operates at the prim level and affects both the visual renderer and the RTX sensor pipeline simultaneously, so you can’t separate the two using that control alone.
Here’s what’s actually going on and the approaches worth trying:
Why this is hard
The RTX LiDAR in Isaac Sim renders against the scene’s BVH (bounding volume hierarchy), which is built from all geometry prims with computed USD purpose "render" or "default". Crucially, this is the same geometry the visual renderer uses. There is no first-class mechanism in the current RTX sensor pipeline to specify “include this prim in LiDAR raycast but exclude it from visual render output.” Stage visibility removes the prim from both. That’s the wall you’ve already hit.
It’s also worth knowing that 3DGS splats (your USDZ) are confirmed to be invisible to RTX LiDAR sensors by design - the splat representation doesn’t participate in the BVH. This has been verified experimentally, so your proxy mesh approach is the right architectural direction.
Option 1 - Fully transparent material on the FBX (most straightforward)
Assign a material to your FBX mesh with opacity = 0 and opacityThreshold = 0. In MDL this means using an OmniPBR material with:
  • opacity_constant = 0.0
  • enable_opacity = true
The RTX LiDAR raycast operates against geometry in the BVH regardless of material opacity - it does not skip transparent geometry. So the mesh stays detectable while being visually invisible. This is the simplest approach and should work without any scripting.
To test: assign the material, confirm the mesh disappears visually in the viewport, then play the simulation and verify the point cloud still appears in RViz2. The mesh needs to remain active (not hidden via the eye icon) for this to work.
Option 2 - Render visibility via Python at runtime
If the transparent material approach has issues with your specific MDL setup, you can drive visual visibility programmatically without touching stage visibility:
from pxr import UsdGeom
import omni.usd
prim = stage.GetPrimAtPath("/World/your_fbx_mesh")
imageable = UsdGeom.Imageable(prim)
imageable.MakeInvisible()
The distinction here is that UsdGeom.Imageable.MakeInvisible() sets the visibility attribute to "invisible" on the prim, which controls visual rendering. Whether this also removes the prim from the RTX sensor BVH depends on the Isaac Sim version - in some builds it does, in others it doesn’t. It’s worth testing in 6.0.0 specifically. If LiDAR detection survives after calling MakeInvisible(), you’re done.
Option 3 - Separate render layers / render products
A more robust but heavier approach: configure two separate render products - one for the viewport camera (which sees only the 3DGS USDZ) and one for the RTX LiDAR (which sees the FBX proxy). You can use Replicator’s render product API to control which geometry each product evaluates. This requires some scripting but gives you clean separation of visual and sensor pipelines.
Recommended path
Start with Option 1 (transparent MDL material). It’s the least invasive and most likely to work in Isaac Sim 6.0.0 without side effects. If LiDAR detection drops after making the material fully transparent, that means the RTX renderer is culling zero-opacity geometry from the BVH, and you’ll need to escalate to Option 2 or 3.
If none of these work as expected in 6.0.0, it may be worth opening an issue at github.com/isaac-sim/IsaacSim - this is a legitimate use case (proxy mesh for sensor + visual asset for rendering) and the lack of a clean API for it is a known gap in the platform.
Let us know what you find with the transparent material test.
Thanks for your suggestion.
I tried setting both opacity = 0 and opacityThreshold = 0.
The mesh became transparent, but it also stopped being detected by the RTX LiDAR sensor, resulting in the same behavior as disabling Visibility.
So unfortunately, this approach doesn’t work for my use case.
Thanks for testing that quickly, and yeah, that result tells us something important.
The fact that opacity = 0 kills LiDAR detection means the RTX pipeline in 6.0.0 is culling zero-opacity geometry from BVH traversal. So Option 1 is definitively off the table for your setup. Good to know, saves others the time.
At this point I’d skip Option 2 (MakeInvisible()) entirely - if full opacity culls the geometry from the sensor pass, there’s a good chance the visibility attribute does the same thing, and you’d just be running the same experiment with an extra step.
What I think is actually the right path here: Non-Visual Materials
This is something I should have led with, honestly. The RTX sensor pipeline has a separate material channel specifically for this situation - it lets you assign sensor-facing properties to a material independently of how it looks visually. The idea is that a mesh can have opacity = 0 on the visual side while still carrying non-visual attributes that tell the RTX sensor renderer to treat the surface as solid and detectable.
The relevant system is omni.sensors.nv.materials / isaacsim.sensors.rtx. As of Isaac Sim 5.1 the old CSV mapping approach is deprecated — the current method is via USD attributes directly on the material prim.
Concretely:
  1. Keep OmniPBR on your FBX with opacity = 0 and enable_opacity = true (visual transparency stays)
  2. Right-click the material prim in Stage > Add > Attribute, and add the non-visual sensor surface attributes per the omni.sensors.nv.materials docs
  3. Alternatively, run the bundled example to see it working end-to-end: ./python.sh standalone_examples/api/isaacsim.sensors.rtx/specify_non_visual_materials.py
The RTX sensor renderer evaluates these attributes in a separate pass from visual opacity, so the LiDAR should still get a solid return even with the mesh fully transparent visually. The key thing to verify is that the prim stays visible in Stage (eye icon on) -non-visual materials don’t help if the prim is excluded from traversal entirely.
Worth testing this before escalating to Option 3 (separate render products), since that’s a heavier lift. Let us know what you get.
Thanks for the suggestion.
I tested the non-visual material approach.
I added the following custom USD attributes to the material:
  • omni:simready:nonvisual:base = bark
  • omni:simready:nonvisual:coating = none
  • omni:simready:nonvisual:attributes = visually_transparent
With the Stage visibility enabled, I also set the material opacity to 0.
However, the FBX is still no longer detected by the RTX LiDAR sensor.
So in Isaac Sim 6.0.0, adding the non-visual material attributes does not appear to keep the mesh detectable after making it visually transparent.
Is there anything else that needs to be configured, or is this expected behavior?
Hello @sakamaki,
Based on the current non-visual materials documentation, this appears to be expected in Isaac Sim 6.0.0. The non-visual material attributes affect RTX sensor material response after a ray-traced hit, but they do not appear to override the visibility/opacity behavior that determines whether RTX LiDAR gets a geometry hit.
If the FBX is using OmniPBR, it exposes Opacity Threshold control.
As a workaround, you could try keeping the mesh visible in the stage and using a very small non-zero opacity:
  • Stage visibility: ON
  • opacity_constant: 0.001 (slightly above threshold)
  • Opacity Threshold: 0.0 or lower than opacity
This could possibly keep the mesh nearly invisible visually while avoiding a full opacity cutout.
If RTX LiDAR still does not detect it, this could be a limitation of the current support.
Hello @vchuang
I tested the suggested workaround using OmniPBR with opacity_constant = 0.01 and Opacity Threshold = 0.0.
The mesh becomes nearly invisible as expected. However, the 3D Gaussian Splatting object overlapping with the mesh also becomes transparent. As shown in the attached screenshot, the leaves and trunk of the 3DGS tree become transparent where they overlap with the FBX mesh, while the wall behind remains unaffected.
I also tested several values of opacity_constant. RTX LiDAR detects the mesh only when opacity_constant is 1.0. For any value less than 1.0, including 0.99 and 0.01, the mesh is not detected by RTX LiDAR.
Based on these results, it seems that any level of transparency prevents RTX LiDAR from detecting the mesh.
Thanks for testing and sharing the detailed result.
Based on this, the material-opacity workaround does not appear to be viable in Isaac Sim 6.0.0 for your use case. This could be our current support limitation for using an invisible FBX proxy mesh behind a visible 3DGS asset.
Thank you for your clarification and for helping me investigate this issue.
I have one additional feature request related to robotics simulation.
Currently, RTX LiDAR cannot detect 3D Gaussian Splatting (3DGS) scenes. Since 3DGS is becoming a practical way to reconstruct real-world environments, it would be extremely useful if RTX LiDAR could interact with 3DGS objects (or if an officially supported non-visual representation could be generated automatically).
This would allow robotics developers to use the same reconstructed environment for both camera and LiDAR simulation, making sensor fusion and Sim2Real validation much more practical without manually creating collision meshes.
I hope this can be considered as a future feature request for Isaac Sim.
Thanks for the clear request and motivation.
I agree this would make camera/LiDAR simulation much easier for sensor fusion and Sim2Real validation, especially with environments reconstructed from real-world data. I’ll capture this feedback as a reference for future feature development.
If there are no further issues, we’ll close this topic for now.
Feel free to open a new thread if you have additional questions. Thanks for reaching out!
Thank you very much for considering my request and for forwarding the feedback to the development team.
I look forward to future improvements to Isaac Sim.
Thanks again!
