how can I make a system installation package from one nano to another? I do not want to configuration environment again?
Examine your command history with the history command and make a script from that to get to the same point is what I might recommend. Then you launch that script on your new Nanos. You can either apply the script in your rootfs as a first boot script or using qemu depending on your needs.
Dupe (buttons small on mobile)
