I use multiple webcams.
I get input buffers from nvbufsurface and infer each surface.
And I draw metas in frame_meta_list in batch_meta.
In case, how can I know which surface matches which frame?
Example codes below.
NvBufSurfTransform(in_surf, memory->surf, transform_params);
for (auto i = 0; i < frame_size; ++i) {
tensorrt->execute();
for (NvDsMetaList* l_frame = batch_meta->frame_meta_list; l_frame != nullptr; l_frame = l_frame->next) {
// How can I match?
Please refer to source code of gst-dsexample. You can enable it by following README at
deepstream_sdk_v4.0.1_jetson\sources\gst-plugins\gst-dsexample\README
Should be more clean to add a print in gstdsexample.cpp:
// Using object crops as input to the algorithm. The objects are detected by
// the primary detector
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
frame_meta = (NvDsFrameMeta *) (l_frame->data);
<b> printf("batch_id %d \n", frame_meta->batch_id);</b>
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
batch_id matches with sources. For example, if you run source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt, you will see batch_id 0 to 7
