How can I monitor the hardware encoder usage (h265)
Software Version
[*] DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
[*] 2.1.0
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
I would like to check the nvenc frequency / usage rate during hardware encoding(h265) using a nvenc.
I thought I could get the status to use tegrastats command, but NVENC is always off status.
Is there another way?
Error String
Logs
RAM 3699/28954MB (lfb 1x4MB) CPU [0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009,0%@2009] EMC_FREQ @3199 GR3D_FREQ 0%@[1274,1274] NVENC off NVDEC off NVJPG off NVJPG1 off VIC off NVDLA0 0%@1331 NVDLA1 0%@1331 PVA0_FREQ @1011 PVA0_VPU0_LOAD off PVA0_VPU1_LOAD off APE 81 CV0@40.968C CPU@43.593C EXT0-local@30.5C EXT1-remote@32.25C SOC2@38.562C EXT0-remote@32.5C SOC0@41.906C CV1@41.843C GPU@42.343C tj@43.906C EXT1-local@36C SOC1@43.812C CV2@39.031C
Dear @atsushi_01_iwai ,
The fix is not available is not part of DRiVE OS 6.0.10.
You can check the frequencies of these at /sys/kernel/debug/clk/nvenc
Please see NVENC shows Off during video encoding using sample application nvm_iep_sci
