I´m using the Jetson Nano with the Azure IOT Edge framework, when I check the logs from the NVIDIADeepStreamSDK docker, I see this output:
“version” : “4.0”,
“id” : 3715,
“@timestamp” : “2020-08-20T09:05:49.158Z”,
“sensorId” : “HWY_20_AND_LOCUST__WBA__4_11_2018_4_59_59_379_AM_UTC-07_00”,
“objects” : [
“1|329|328|674|616|Vehicle|#|||||||0”,
“288|196|538|610|857|Vehicle|#|||||||0”,
“289|1323|244|1391|258|Vehicle|#|||||||0”
is ok, but I would like to put a clear name to each of the sources, for me “sensorId” : “HWY_20_AND_LOCUST__WBA__4_11_2018_4_59_59_379_AM_UTC-07_00” has no sense, and the id is also no-sense.
I tried to use the camera-id property in the configuration file, but the output is the same.
how can I put a name to each source?, so in the output I can see for example “camera1” or “camera_frontdoor”
Regards.
