How can I obtain raw image datas in deepstream-app sample?
**• Hardware Platform (Jetson / GPU)**Jetson
• DeepStream Version6.1.1
**• Issue Type( questions, new requirements, bugs)**questions
Hi,guys!I am trying to get the angle of each detected object.To realize this ,I write the code below in the
gie_processing_done_buf_prob (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
this function belongs to deepstream_app.c,the codes is :
  GstBuffer *buf = (GstBuffer *) info->data;
  NvDsInstanceBin *bin = (NvDsInstanceBin *) u_data;
  guint index = bin->index;
  AppCtx *appCtx = bin->appCtx;
  NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
  for (NvDsMetaList * l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
      NvDsFrameMeta *frame_meta = l_frame->data;
      for (NvDsMetaList * l_obj = frame_meta->obj_meta_list; l_obj != NULL;
        l_obj = l_obj->next) {
        NvDsObjectMeta *obj = (NvDsObjectMeta *) l_obj->data;
        cv::Rect bbox(obj->rect_params.left, obj->rect_params.top,
                      obj->rect_params.width, obj->rect_params.height);
        GstMapInfo map;
        gst_buffer_map(buf, &map, GST_MAP_READ);
        cv::Mat frame(cv::Size(frame_meta->source_frame_width, frame_meta->source_frame_height),
                      CV_8UC3, (uchar*)map.data, cv::Mat::AUTO_STEP);
        gst_buffer_unmap(buf, &map);
        cv::Mat object_img = frame(bbox);
        float angle;
        Ellipse_feature_extraction2(object_img,angle);
As you can see there are some codes involving opencv like cv::Rect which shouldn’t appear in C file.I will handle that later.
The logic,as you can see, is very simple.I want to cope with every object to get an angle using my costum function Ellipse_feature_extraction2 in every frame.
To realize that ,I need the frame by frame raw image and do ROI,so the codes:
        GstMapInfo map;
The codes above are the steps to get the raw image and do ROI,but it seems that map.data are not the raw image datas I want.
So my question is, to realize the opinions I mention,what changes the codes should make.
Please refer to our source code convert_batch_and_push_to_process_thread in the sources\gst-plugins\gst-dsexample\gstdsexample_optimized.cpp .
The inter_buf in that function is similar to your buf.
I have roughly see the codes,it involve the dsexample plugin,if I don’t want to add the element in my pipeline,are there others way to get the raw images frames?
I’m not asking you to add the dsexample plugin, just refer to the source code it uses to process the buffers. We have many similar examples for this, like 142683 etc…
