I am trying to read the sheer script of the usd file created from the sample connector code. Do you know a method for that?
Hi @Ai-da! If I’m understanding your question correctly, you can save your USD layer as .usda. This is the ASCII format which you can then open open in any text editor.
Thanks for responding. I figured that one out through some search but when I try to save my usd file as a usda it keeps giving me an error saying it can not save the layers.
I can’t believe it was that easy.
Thank you very much.
