How can I received a packet bigger than 9000 bytes from GBE interface!
Hi:
I want to receive data form a GBE interface camera, the camera use jumbo frame which bigger than 9000 bytes, I do below changes:
1. Change MTU size to 16380: change OSI_MTU_SIZE_9000 from 9000 to 16380 in file osi_core.h.
2. Compile kernel.
Now I can send net packet bigger than 9000 bytes such like 9800.(use ping command). But I can’t receive packet bigger than 9000 bytes, the biggest packets is 8970 bytes.
How can I received a packet bigger than 9000 bytes from GBE interface! Thank you!
Anyone can help?
There is a limitation that MTU size over 9000 is not supported with multiple DMA channel configuration.
