Hi, guys,
I’m no usable develop carry board and I couldn’t enter recover mode work with our carry board.
I usually reflash the “kernel-dtb” partition via “flash.sh” script with “–no-flash” to generate the target file and the flash it into “kernel-dtb” partition “/dev/mmcblk0p36” by the “dd” command.
Now, I want to use the same method to reflash the “MB1_BCT” partition, but I found there’s not a “MB1_BCT” partition exist on the device. but this partition is exist in the config file “bootloader/flash.xml” as below, why?
And any idea to reflash it without recover mode?
36
37 <allocation_policy> sequential </allocation_policy>
38 <filesystem_type> basic </filesystem_type>
39 65536
40 <file_system_attribute> 0 </file_system_attribute>
41 <allocation_attribute> 8 </allocation_attribute>
42 <percent_reserved> 0 </percent_reserved>
43 Required. Slot A; contains MB1 boot configuration table.
44
Thank you in advance!
