I am interested in measuring power usage, how can I run at the input rate instead of the max processing rate? Currently it processes a 10 FPS video at about 18 FPS
Here is my config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[source0]
enable=1
type=3 # 3 for video, 4 for rtsp
uri=file://video.mp4
# uri=rtsp://192.168.1.8:8554//vis.0
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=1
sync=0
gpu-id=0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
frame-duration=100
[primary-gie]
enable=1
gpu-id=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[secondary-gie0]
enable=1
gpu-id=0
gie-unique-id=2
operate-on-gie-id=1
nvbuf-memory-type=0
config-file=config_infer_secondary.txt
[tests]
file-loop=0
Jetson
• DeepStream Version
6.2
5.1.1
• TensorRT Version
8.5.2
Question
