How can I run jetson_clocks automatically after reboot every time?
How can I run jetson_clocks automatically after reboot every time?I would like to run max performance.
You can use systemd to do it.
Please refer to
https://devtalk.nvidia.com/default/topic/1000657/jetson-tx2/script-for-maximum-clockspeeds-and-performence/post/5241246/#5241246
please note that jetson_clocks is now placed in the PATH so we don’t need to specify absolute path but just “jetson_clocks”.
Hi,there.I have followed this,but it not worked.
On the AGX I created a startup service named jetsonClocks.service with the below lines of code in it and put it in etc/systemd/system folder:
[Unit]
Description=Maximize Jetson Performance
After=multi-user.target
[Service]
ExecStart=/bin/sh /home/sf/zqm/clocks.sh
[Install]
WantedBy=multi-user.target
In the clocks.sh file just put:
#!/bin/bash
# Maximize performance on the Jetson
# How long would this hold up in a long environment? No idea
sleep 6
jetson_clocks
exit 0
Then I run the following commands to enable the service
sudo chmod 644 /etc/systemd/system/jetsonClocks.service
sudo systemctl daemon-reload
sudo systemctl enable jetsonClocks.service
sudo reboot
But nothing happened.And I run
sudo clocks.sh
It worked that Maximize performance on the Jetson.
Not sure why but you can check the status of systemd by running
sudo systemctl status jetsonClocks.service
This worked fine for me
[Unit]
[Service]
ExecStart=/usr/bin/jetson_clocks
[Install]
Hi,there.I use your jetsonClocks.service file,and reboot my device.it doesn’t work,and the service status:
jetsonClocks.service - Maximize Jetson Performance
   Loaded: loaded (/etc/systemd/system/jetsonClocks.service; enabled; vendor preset: enabled)
   Active: inactive (dead) since Wed 2019-11-13 10:41:36 CST; 1min 7s ago
  Process: 4800 ExecStart=/usr/bin/jetson_clocks (code=exited, status=0/SUCCESS)
 Main PID: 4800 (code=exited, status=0/SUCCESS)
11月 13 10:41:35 sf-desktop systemd[1]: Starting Maximize Jetson Performance...
11月 13 10:41:36 sf-desktop systemd[1]: Started Maximize Jetson Performance.
after reboot,the jetson_clocks status:
SOC family:tegra194  Machine:Jetson-AGX
Online CPUs: 0-7
CPU Cluster Switching: Disabled
cpu0: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu1: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu2: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu3: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu4: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu5: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu6: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
cpu7: Online=1 Governor=schedutil MinFreq=1190400 MaxFreq=2265600 CurrentFreq=1190400 IdleStates: C1=0 c6=0
GPU MinFreq=318750000 MaxFreq=1377000000 CurrentFreq=318750000
EMC MinFreq=204000000 MaxFreq=2133000000 CurrentFreq=2133000000 FreqOverride=1
Fan: speed=255
NV Power Mode: MAXN
And I try to modify nvpmodel.service:
[Unit]
Description=nvpmodel service
; Everything depends on the NVIDIA per-boot script
After=nv.service
Requires=nv.service
; TPC power gating must be enabled before anything touching gpu
Before=graphical.target
Before=gdm3.service lightdm.service
[Service]
Type=simple
##################ExecStart=/usr/sbin/nvpmodel -f /etc/nvpmodel.conf
[Install]
and reboot ,it worked.I am confused that.
You can also try the rc.local
