How can I save the detected image after executing detectnet.py to drive?
Hello! How can I modify detectnet.py to save the detected image to my local drive?
detectnet.py by default supports using images as input.
For example:
https://github.com/dusty-nv/jetson-inference/blob/master/docs/detectnet-console-2.md#detecting-objects-from-images
$ ./detectnet.py --network=ssd-mobilenet-v2 images/peds_0.jpg images/test/output.jpg
You can change the images/peds_0.jpg to the path of your images on the local drive.
Hi AastaLL,
Thank you for the response. But what I mean is that I am running my model on a live camera stream, and I want to save an image every time something is detected and save it to my local drive.
I saw from another topic that I can use detectnet-snap.py. I tried running the code, and it worked, but when I view the directory where the images should be stored, no file is saved.
Reference topic: Snap Image when detection (without bounding box) and save into a folder
Is there any error message output when saving the image?
Could you also try to use the absolute path in the below link to see if it works?
I have already tried running the code without specifying my own directory or using the --snapshots option.
Below is the output when running the code with the default path:
And here is the result when I attempted to locate the default path:
Thank you for your assistance!
Hi
Could you search the file to see where it is stored?
$ sudo find / -iname 20250102-155717-532264-0.jpg
It should be under the build folder or beside the binary location.
