Hello everyone,
I’m going to link a webcam called imx477 to Jetson Nano and run vlc on another host computer for real-time streaming.
First, I got the exclusive library for Ardu Cam and installed it. The screen worked fine.
(IMX477 - PTZ Camera - Arducam)
However, there was a problem with the real-time streaming that I tried for the second time.
(FFmpeg를 사용하여 웹캠 영상과 동영상 파일을 RTSP 스트리밍하기(RTSP streaming webcam / video files using FFmpeg) - 멈춤보단 천천히라도)
On that site, the camera format format is YUYU, mpeg, while I came out in RG10 format.
$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 4032x3040
Size: Discrete 3840x2160
Size: Discrete 1920x1080
Interval: Discrete 0.017s (60.000 fps)
I’ve been looking for ways to run the code in RG10 format.
$ ffmpeg -f v4l2 -list_formats all -i /dev/video0
ffmpeg version 3.4.8-0ubuntu0.2 Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[video4linux2,v4l2 @ 0x5590719640] Raw : Unsupported : 10-bit Bayer RGRG/GBGB : 4032x3040 3840x2160 1920x1080
/dev/video0: Immediate exit requested
However, we are unable to find any way because of the error that the format does not support.
Is my camera not compatible with v4l2? What should i do now?
