Hi Nvidia,
We try to verify eye diagram of HDMI .
I follow the document to disable the HDP and conect the HDMI port to oscilloscope.
But how can I set HDMI resolution by SSH or UART cmdline?
I use xrandr but can’t open display.
~$ xrandr --output HDMI-0 --mode 1024x768 --rate 60
Can't open display
~$ xrandr -display :0.0 --output HDMI-0 --mode 1024x768 --rate 60
No protocol specified
Can't open display :0.0
Are you able to adjust it if you are doing it on screen?
When you operate it in ssh, are you running as root?
Yes, it worked on screen.
I try to sudo in ssh and get same error.
I mean you cannot run sudo in xrandr.
Hi Wayne,
I don’t run root at first. I tried both and got same error.
~$ xrandr --display :0.0 --output HDMI-0 --mode 1024x768 --rate 60
Can't open display
~$ sudo xrandr --display :0.0 --output HDMI-0 --mode 1024x768 --rate 60
~$ sudo xrandr --output HDMI-0 --mode 1024x768 --rate 60
Can't open display
please try command xhost + on your jetson first and then test again.
It’s still error.
My step:
command xhost + on jetson ubuntu screen.
~$ xhost +
access control disabled, clients can connect from any host
test xrandr in ssh again and still error.
Hi @WayneWWW
I echo the $DISPLAY is :1
I try to following cmd is worked.
xrandr --display :1 --output HDMI-0 --mode 1024x768 --rate 60
Thanks your help.
system
Closed
June 7, 2023, 2:43am
11
