How can I set the dtsi file use YUV sensor at TX2 r32.2?
It is bypass the ISP function,is RIGHT?
How can do it ?
and how can set the "devname "value ?
hello sensor_test,
yes, YUV sensor would perform the image process with the built-in ISP.
please assign devname as its v4l2 device name, since you should also consider it as normal camera sensor.
you should also note that,
please execute with v4l2src to access YUV sensors. you may also check Camera Architecture Stack for reference.
thanks
