How can I setting ISP with GStreamer
I want to setting ISP with GStreamer
so I want to know the way setting ISP with GStreamer.
And, I found out that ISP can be set in Camera_overrides.isp file.
Can I create and modify that camera_overrides.isp file?
hello tnals,
it’s image quality tuning related settings within ISP override files.
actually, we do not support that through forum discussion threads, please contact with sensor vendor for further supports.
So, is there a way to set up the ISP using GStreamer?
hello tnals,
please see-also Camera Architecture Stack.
it’ll uses Jetson ISP when you running camera via libargus.
Thank you.
I have a last question.
If you look at the .dtsi file as below, the values are written for each item. If I change the value, does the quality of the camera image change?
hello tnals,
no, those are property settings for each sensor mode of driver implementation.
please see-also developer guide, Individual Imaging Devices for reference,
Thank you.
And then, What should I do if I want to set the .dtsi of IMX219?
hello tnals,
I don’t understand your question clearly. may I have more details or your real use-case.
FYI, device tree settings used to store all the needed (sensor capability) information, in order to register sensor device as a V4L2 subdevice, and, it’s driver side to retrieve everything driver operation needs from device tree.
I will be using Jetson Nano and IMX219 camera.
However, when I looked it up, I found information about adding a camera module to the device tree as shown below.
So I’m wondering if I need to create a .dtsi file for IMX219 and add it.
you should no bother with that, it’s by default support Raspberry Pi v2, imx219.
Thank you for your reply
