Hello!
I have some trouble with my I2C3 device.
I added I2C3 in device-tree (tegra124-apalis-eval.dts file).
/*I2C3 Enable CAM AR0134*/
i2c@7000c500 {
status = "okay";
clock-frequency = <100000>;
And I add pinmux in tegra124-apalis-pinmux.dtsi.
/* Apalis I2C3 (CAM) */
cam_i2c_scl_pbb1 {
nvidia,pins = "cam_i2c_scl_pbb1";
nvidia,function = "i2c3";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,open-drain = <TEGRA_PIN_ENABLE>;
cam_i2c_sda_pbb2 {
nvidia,pins = "cam_i2c_sda_pbb2";
But when I use i2cdetect, only this shows up.
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
And also I don’t see clock on cam_scl_pin. I checked pull up resistor on my circuit board. It’s ok.
What’s maybe wrong?
Sorry for my English.
Thank you!
