How can I solve error:" ln: failed to create symbolic link ‘./subsystems’: Operation not permitted" during soft link creation in setting up the NVMe over fabric, while i am a root user!
I am trying to setup NVMe over Fabrics using your post at “https://community.mellanox.com/s/article/howto-configure-nvme-over-fabrics”.
I could reach step 10, but when I try to create the soft link according to step 10 as a root user, I am getting error:
I search a lot but I could not find any solution!
I appreciate if you help me.
Best,
Marjan
Semmes like you have a configuration issue, with possible parameters-mismatching between “NVME-port” and “nvme-subsystem-name”.
Mainly check that the path to the NVMe device (e.g. /dev/nvmeon1) is correct that namespace is enabled, rdma-port is identical etc.
Other than that, check in Mellanox website support section all compatibility aspects between the mlnx_ofed Linux driver version vs. supported Linux OS vs. Mellanox adapter’s fw etc…
