I tried:
#X: 1 /*start second X server
Which gave me the error:
(EE) AddScreen/ScreenInit failed for driver 0
Do I need to use an other command or is it a driver problem ?
I tried:
How have you configured the second X.Org? I would assume they can’t e.g. use the same display. I don’t know at all, if the driver would support two X.Orgs on different displays…
Is should be possible to switch between X Servers (localhost:0.0 and localhost:1.0) with CTRL-ALT-F7 and CTRL-ALT-F8 when you got the second X Server running.
http://ubuntuforums.org/showthread.php?t=213756
This would enable to run a second Window Manager for graphical login to local host or remote host.
An other way would be to use VNC Server for a graphical login on a remote device, but
currently this seems to be limited to a unity-session (I tried this with tightvnc server on a Ubuntu 12.04 box).
