How can i submit two kernels async in stm
Software Version
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
[*] 1.9.2.10884
other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
I can not submit two kernels with two cuda streams asynchronously, how can i do that
my yaml is:
Version: 3.0.0
gpu_multistream_multiprocess:
  Identifier: 101
  Resources:
    CPU:
    - CPU0
    - CPU1
    GPU:
    - iGPU
  Hyperepochs:
  - hyperepoch0:
      Epochs:
      - epoch0:
          Period: 100ms
  Clients:
  - clientGpuX:
      Resources:
        CUDA_STREAM:
        - CUDA_STREAMX: iGPU
        - CUDA_STREAMY: iGPU
      Epochs:
      - hyperepoch0.epoch0:
          Runnables:
          - submit1:
              WCET: 10ms
              Dependencies: []
              Submits: clientGpuX.kernel1
              Resources:
              - CPU
              - CUDA_STREAM
          - kernel1:
              WCET: 1ms
              Dependencies: []
              Resources:
              - GPU
          - submit2:
              WCET: 10ms
              Dependencies: []
              Submits: clientGpuX.kernel2
              Resources:
              - CPU
              - CUDA_STREAM
          - kernel2:
              WCET: 1ms
              Dependencies: []
              Resources:
              - GPU
code:
cudaStream_t m_streamx, m_streamy;
cudaEvent_t start, stop;
int* canaryHost;
int* canaryDevice;
//static int testVal;
void submit1(void* params, cudaStream_t stream)
    (void)params;
    testKernel1(stream);
    fprintf(stderr, "In submit1 start\n");
    sleep(1);
    fprintf(stderr, "In submit1 end\n");
void submit2(void* params, cudaStream_t stream)
    (void)params;
    testKernel2(stream);
    fprintf(stderr, "In submit2\n");
void test1(void* params)
    (void)params;
    fprintf(stderr, "In test 1\n");
void test2(void* params)
    (void)params;
    fprintf(stderr, "In test 2\n");
int main(int argc, const char** argv)
    (void)argc;
    (void)argv;
    assert(cudaStreamCreateWithFlags(&m_streamx, cudaStreamNonBlocking) == cudaSuccess);
    assert(cudaStreamCreateWithFlags(&m_streamy, cudaStreamNonBlocking) == cudaSuccess);
    stmClientInit("clientGpuX"); // Needs to be called before registration
    // stmRegisterCpuRunnable(test1, "test1", NULL);
    stmRegisterCudaSubmitter(submit1, "submit1", NULL);
    stmRegisterCudaSubmitter(submit2, "submit2", NULL);
    // Register all resources in the workload
    stmRegisterCudaResource("CUDA_STREAMX", m_streamx);
    stmRegisterCudaResource("CUDA_STREAMY", m_streamy);
    stmEnterScheduler();
    cudaDeviceSynchronize();
    stmClientExit(); // Removes all STM data structures. Can't use STM calls anymore after this.
Dear @moyanhan,
Could you share the complete code and command to reproduce the issue on my machine?
I just add one more submit in stm sampe(cpu_gpu_simple)
code path: driveworks/samples/src/stm/cpu_gpu_simple/clientX/main.cpp, just like the code above
command: stm_mater -s gpu_multistream_multriprocess.stm -l x.log -e 100 & sudo stm_test_gpuX
my purpose is to make sure that mutex is work, while i found that submits runs synchronously without mutex.
thx
Dear @moyanhan,
I ran the sample and notice below output.
In submit1 end
In submit2
In submit1 start
In submit1 end
In submit2
In submit1 start
In submit1 end
In submit2
In submit1 start
In submit1 end
In submit2
In submit1 start
In submit1 end
In submit2```
Do you expect overlapping of submit1 and submit2 prints?
Hi @SivaRamaKrishnaNV
Yes, it seems that submit1 and submit2 running with no overlap.I think submit1 and submit2 should run asynchronously without mutex between them.Can you tell the reason why there no overlapping of submit1 and submit2 prints?
thank you very much
Dear @moyanhan,
As GPU is a unique resource, it will automatically push serialization upstream for all the submitters.
Dear @SivaRamaKrishnaNV ,
Then what’s the meaning for the CUDA_MUTEX if it push upstream serially?
thx
