Thank you for the link. However, the User Manual appears to be a bit older. Do you haven any guidelines for CUDA 10.1/11 or MLNX_OFED5.0-2.1.8.0-ubuntu18.04, openmpi-1.10.7?
I run into many issues when following those instructions with the latest software pieces.
Additionally, I believe the benchmarks highlighted in this manual, involves a mulit-host system, but I only have a single CX5 card and want to test GPU Direct to a single GPU on the same PCIe heirarchy.
Currently I have an ethernet cable plugged in loopback on the CX5.
Are you able to provide any updated instructions. Additionally it would appear the instructions also need to be modified for testing only a single NIC to a single GPU on the same PCIe topology.
