How can I use memory without using CUDA shared memory?
__global__ void sortBlocks(int *a)
	int i = 2;
	__shared__ int temp[THREADS];
	//int temp[THREADS];
	while (i <= THREADS)
		if ((threadIdx.x % i) == 0)
			int index1 = threadIdx.x + (blockIdx.x * blockDim.x);
			int endIndex1 = index1 + i / 2;
			int index2 = endIndex1;
			int endIndex2 = index2 + i / 2;
			int targetIndex = threadIdx.x;
			int done = 0;
			while (!done)
				if ((index1 == endIndex1) && (index2 < endIndex2))
					temp[targetIndex++] = a[index2++];
				else if ((index2 == endIndex2) && (index1 < endIndex1))
					temp[targetIndex++] = a[index1++];
				else if (a[index1] < a[index2])
				else
				if ((index1 == endIndex1) && (index2 == endIndex2))
					done = 1;
		__syncthreads();
		a[threadIdx.x + (blockIdx.x * blockDim.x)] = temp[threadIdx.x];
		__syncthreads();
		i *= 2;
Here is the code to mergesort. In this function, as in the code above, “int shared temp [THREADS]” like this this fine works.
But without using shared memory “int temp [THREADS]” This makes the value output strange.
Why is that? How do I allocate memory if I don’t use shared memory?
The THREADS value is 512.
any local variable in the heap is usually local to each thread, with the exception of variables with the shared qualifier. In other words, you’ll now have THREADS independent versions of an array of size THREADS.
you can also use malloc() in one thread of the block and pass the resulting pointer to other threads (ironically that’s best done through shared memory). Also don’t forget to free() the memory when the thread block has finished doing its work.
