How can I use my TensorRT engine with a video file with the trtexec command ?
I converted my yolo model to onnx using yolov3_to_onnx.py. than I converted yolov3.onnx to yolov3.engine for TensorRT C++ API. I want to test yolo.engine with video file. I tried to using trtexec command but I couldn’t. How can I test on video file using with my yolo engine ?
I think “trtexec” doesn’t support a video file as input.
Please refer to below sample example:
https://github.com/NVIDIA/object-detection-tensorrt-example
Do you have anything yolo-tensorRT example for tensorRT C++ API ?
thanks for your help.
Currently we just have yolo-tensort sample using python API.
https://docs.nvidia.com/deeplearning/sdk/tensorrt-archived/tensorrt-700/tensorrt-sample-support-guide/index.html#yolov3_onnx
But after converting yolo to onnx you can refer following sample for ONNX to TRT conversion:
https://github.com/NVIDIA/TensorRT/tree/release/7.0/samples/opensource/sampleOnnxMNIST
hi,
Do you have anything tensorRT C++ API example for video file ?
thanks
Please refer to below code samples, hope it helps:
https://github.com/dusty-nv/jetson-inference#code-examples
