Hi cookecaius,
I see in your separate later post Map/unmap causing persistent frame stutters, what do I do? that you managed to run and trace Black Ops Cold War from within Nsight Systems. I assume you used Nsight Systems to launch the launcher.
Tracing child process is enabled by default when tracing on a Windows machine.
I will address the questions in your other post on that post page.
Doron
