zax
August 15, 2023, 1:53am
1
Platform : AGX Orin
Jetpack : 5.1.1
board : custom carrier board
We are using AGX Orin with our custom board, and we have a micro usb for flash port
We want to use ssh on host to connect with this board
So we enable the micro usb OTG function by nvidia document( but actually I just want device mode function)
But this action( enable the micro usb OTG function) cause another usb typeA slow down to 5000M by checking command “lsusb -t”
This type A is directly using usb2-0 and UPHY0 come out of SOM(its speed should be 10000M)
I don’t know why micro usb may affect another type A
On the other hand, our hardware tell me that this micro usb doesn’t support OTG function
Because there’s no ID pin on micro usb
My question is how can I use ssh with my type A has 10000M speed?
Please help to solve it
Thanks for hlp
Actually you should provide the schematic, your device tree and the dmesg.
Please be aware that we are not your colleague so know nothing about your board and there are lots of reasons could lead to usb fail to work.
The dmesg when you reproduce the problem you want to ask.
zax
August 15, 2023, 2:57am
6
Here’s dmesg log
dmesg.txt (84.2 KB)
Here’s lsusb result, the testing device is Kingston usb 3.2 gen2 (https://www.kingston.com/datasheets/dtmaxa_us.pdf )
please convert your dtb back to dts and attach that dts here.
Could you also share the log where you cannot reproduce issue?
I mean when the timing you saw the Kingson drive becomes gen2.
zax
August 15, 2023, 3:58am
10
When I change back the otg to origin settings, the speed is gen2, but ssh can’t be using
dts
dmesg
dmesg_ucsi.txt (83.4 KB)
lsusb
If you just totally disable usb2-0 and CCG, what will be the result on usb2-1+usb3-0?
zax
August 15, 2023, 4:29am
12
Disable usb2-0 could cause flash port can’t work?
I can try to disable them, but it may not be use for my case
because I need the usb2-0 for flash
這只是debug的過程
I know. It is just debug purpose.
zax
August 15, 2023, 7:02am
16
Sorry that the former testing is wrong
After correctly disabled 2-0 and CCG
The result on usb2-1+usb3-0 is 10000M
Here’s dmesg and lsusb
dmesg_dis2-0.txt (82.5 KB)
Based on this test, I would say please correct the hardware on that micro usb first. And modify the DT accordingly.
You cannot use a wrong configuration/dtb to prove something would work. That could just be coincidence.
zax
August 15, 2023, 7:55am
18
So if I need the ssh function on my micro usb, I can just porting the OTG as the document mentioned?
And because our hardware has no ID pin, the ssh function can work might be just coincident
So your advice is make the hardware correct to support this function, is that right?
Actually “no ID pin” is ok design if you only want to use device mode. You could refer to how the device tree is written in Xavier NX devkit dts.
That board also has no ID pin and only works in device mode.
zax
August 15, 2023, 9:52am
20
Okay, Thanks for your great help
I will try it
system
Closed
September 11, 2023, 7:59am
22
